Dell question pls help
marikso
So I bought a Dell U2312HM and it had some serious backlight bleeding,I contacted Dell and told me they'll send me a new one and I should give them the faulty one.
They will send it by courier..
Is there any way I can test the newly received monitor with the courier near me(but he might not be from dell service)...so if the new one is bad I can return it on spot there,without going through all the process again and again until I find a good monitor?
No, there is not, but if it is bad they will send you one until it is right.
If you do an RMA with Dell they'll drop off the new monitor and you have a set amount of time to send back the old one. If the new one is worse than the old, keep the old one. At least that's what I did.
