Dell Quadro's I need an experianced 3d computer tech?
Does anyone know anything about ebay selling Dell quadro's?
I've seen so many online I'm starting to wonder about the validity and usability of them on a hand built PC I made.
Does my computer have to be a Dell to use those cards?
I intend on using them for a fairly intensive 3D CAD07 3dvis and 3d studio rendering program but I'm also curious about the gaming aspect of the 1500$ and up cards. From what I've seen my processor seems to give out before the video card so I will be looking at that later. (definately in the quad core xenon range for sure maybe even two processor board)
Do you think that I obtain one of the quadros I can still run high end games too?
I also need someone to help me modifiy my current settings to max them out without killing my computer.
Current Specs:
Do note I have the antec gamer 900 case with all the fans
core 2 duo 6420
asus p5n32-sli premium
4 gig 666mhz ram Kingston (kvr667d2n5k2) ( i don't know how to modify the bios with their proper setting to OC them)
BFG 7950 GT OC 512mb DDR3
Sata hd's
750 HD thermotake power supply
The quadro's are not designed for games, so you may suffer greatly on performance, also dell cards should work in all computers. thats all the can help you with.
I assumed I could use the same video card, but I also know Dell likes making proprietary components. I've seen one particular quadro 5500 which intrigues me so thats why i was wondering about the game side.
Workstation cards will not work well in games. Also, your processor is absolutely fine for gaming. If you really want, you can overclock it for some measly fps gains.
Not sure why people say those cad cards are horrible for games. I've got a Dell M90 Presiscion running a quadro 2500m. I've got it running WoW, Portal, HL2 all at 1080P on my 42" downstairs. Wow runs at 60fps in Shat at 4xAA16xAF
its not as fast as a fullblown 7900gtx, but its not horrible by any means.
I've heard the same thing but one would think the quadro 5500 would make any card on the market right now look like a puppy. Especially for 3000$
The FX 5500 is pretty old, you'd be better off with an FX 4600, it's faster. The 5500 uses the G71 core and the 4600 uses the newer G80 core. The 5500 will perform like a 7900GTX when gaming, if that helps with your decision.
Thanks for the info on that one ND40oz. Do you know if that 4600 does dx-10? or any card for that matter in the quadro line? It is important for me to stay in this line due to the nature of how much i will be spending and the versatility of the card given what I do. If anyone has any other ideas I'm open to discussion. Also note that autocad 2009 is soon coming out which may change things as well.
4600 and 5600 are DX10, they're essentially 8800GTX's with 768 or 1536 megs of memory. Hopefully will see some G92/94 based cards out soon, but who knows.
Hey lets throw in a curve ball here what about the newest highest bfg 9 series. Any opinions on heavy visual 3d render video aps and the newer cards?
They definitley won't be as good as the quadros in professional apps. Only the 9800GTX or 9800GX2 would beat a 4600 when gaming. 9600GT, no way.
It would be interesting to see how the 1.5 gigs of memory helps the 5600 when gaming at high res with tons of AA.
Is it possible to have one of those old switch boxes for two different video cards?
I certainly have the space in my computer just another thought :p
From the way things are looking on my other post about the processor bit I think I may run into issues with my processor
You know what, I forgot that the FX3700 came out. It's based on the G92 used in the 8800GT. You may want to try it and see how it does. If you find you need more, just buy a second and SLI them. You can always upgrade to a Q6600 if you find your E6420 can't keep up, but it's no slouch, especially if you start overclocking.
http://www.hothardware.com/Articles/Nvidia_QuadroFX_3700_512_MB/
What about using RivaTuner to unlock the "professional capabilities" of a regular card?
Or does that not work anymore?
index.cfm
I'm going to try and show you what I have this way
http://viewmorepics.myspace.com/ind...&MyToken=31d9db0d-4324-4f17-b52f-1f5390214633
I woud certaily like to OC that processor but I don't have two sweet clues on how to do it other than the AI booster. I think this is one of the most customizable boards out there but I don't know how to take advantage of it. My temps stayed at 44 deg celciius when OC at 10% which really didn't change the temp too much at all. I messed with the bios ealier and I had to pull the battery lol. So yeah no clue.
so these values 4-4-4-12 where exactly should i be filling them out. I have everything on auto under memory timing config
t(cas) Auto
t(rcd) Auto
t(rp) Auto
t(ras) Auto
t(rc) Auto
Adressing mode (auto)
also do you even think it would be advisable on trying to oc the ram given the name of them?
