I have a Dell Precision 410 that I am trying to get to run with an upgraded power supply from PCP&C. I got their 425watt with the Dell wiring harness. Here's the problem. When I power the unit up, it says that the PS fan tach is reading 0 RPM, the fan is dead (which it isn't), and then it shuts down to "protect" the computer. Machine is flashed to most recent BIOS version, but there is no option to disable this stop error. Doing some comparison, I see that there is 1 wire missing from the PS from PCP&C. I spoke with a tech rep at PCP&C, and they said that it was unneeded, and was missing on purpose. I described my problem to them, and they are willing to wire the PSU fan tach to that lead, but that since it would then be a "custom" PS, that I would not be able to return or exchange it should it still not work. I've looked all over, and have been unable to find a detailed pinout for the Dell proprietary power sullpies, to see if the fan tach does go where the missing lead is. Has anyone else run across this situation and/or can anyone tell me definitively where the PSU fan tach reads from?
Thanks
EDIT: Precision 410, not Optiplex
Thanks
