I figured it could be a 5000X mobo issue so I thought I'd stick it here. I ordered some Dell Precision 490's for a client (single 5130).I'm trying to use an NVS400 with one of them without success.
(For the unfamiliar, the NVS400 is a regular old PCI bus 2D-specific quad-monitor display) I've had long dealings with NVS400's, ever since it came out and it's never failed to work on any PC I've stuck it in - until the Precision 490.
Thinking 'well that's weird', for a test I tried my NVS400 that I had working in the A8N-SLI out on my Precision 690 (2 x 5160). Didn't work. Thinking well maybe the 5000X doesn't support PCI cards I ordered an NVS440 (basically the PCI-E NVS400). No effin' dice either. Once again doesn't worn in my 690's but does work on my A8N-SLI's - and of course doesn't work on the 490.
WTH? Can't get a quad-monitor card in a workstation? I'm wondering what is going on - while Dell are great when you say 'something's broken' they're hopeless in situations like this when you're not using a vendor-supplied card.
Any ideas what could be the problem? Thanks.
