Dell PowerEdge 840 - no boot options
Eiolon
I am trying to boot to a CD (hell, I'd even take USB at this point) but I do not have any options with my PowerEdge 840.
Here is what I get:
F2 = Setup
F10 = Utility Mode
F12 = PXE Boot
I also made sure that I pushed all the other F# buttons just in case and tried moving CD-ROM to first in boot order.
Any ideas? I've got a couple other PowerEdge model servers and there is no problem.
does the BIOS have an option to remove the Boot Device option from the splash screen?
I know you can disable PXE Boot and I beleive Utility Mode.
No, I double checked that. It has a "OS Install Mode" which I turned on just in case, but no luck.
