Does anyone know where i can find some generic/3rd party or dell ears for a PowerConnect 6024?
Try ebay? I am sure someone must have some for sale.
I'll talk to him tomorrow. I may need help with patterns/samples. I have PC 5012, 5224, 3424, 2824, and maybe something else.
If there really is enough interest, I could have some laser cut out, bent, and painted. Would look like factory pieces.
factory pieces are powder coated, not painted
You would probably need quite a bit of moisture to have them rust...
If you are getting rust on your rack ears, you have WAY more other things to worry about...
Paint will start peeling-off first time you seat a screw, then rust. Powder coating bonds to the metal.
Yes I can also have them powder coated.
I do not have the time or want to argue however why your statement is incorrect. A proper paint job, which includes surface prep, primer, and the correct paint will not chip or allow rust to form.
Do me a favor and drop it. I never said powder coating is a inferior process to painting and I am not arguing, I am also stating a fact. Any decent epoxy paint (which I have seen more then powdercoating on many server cases and rack gear) will hold up to years of abuse. http://www.krylon.com/products/epoxy_enamel_paint/
Powder coating is a wonderful process and I have a complete setup in my shop, waiting for me to have time to build a larger oven. However again, for this purpose a basic coat of paint would suffice. Like others have said, if you are worried about rust in a server room or even your home office, you have greater problems.
This is a part people are not going to pay more then $10 for, and why should they? It is a flat sheet with 6-8 holes drilled in it, bent, de-burred, and finished.
anything ever turn up on this?
Still need my Dell PowerConnect 6024 ears
