I recently picked up a Dell PowerConnect 2748 switch locally for $30 that was pulled from a working environment. It's a nice upgrade for my home network as I no longer need to daisy chain 5 and 8 port gigabit switches. The only issue is the fan noise. I realize that these are generally designed for data center usage where noise doesn't matter, but is there a mod that is can be done to quiet these things down? Can I disconnect the fans entirely - the environment it will live in is pretty dry/cool being installed in my basement that stays 55-60F year round.
The fans are on the left side of the case, with slits on the right side to draw air across the case. I haven't opened it up yet, but would it to see physical clearance, but could I just mode the case to have a 120mm fan blowing out and block off the nearest vents so air still gets drawn over the components? Maybe change the fans out to something less powerful since the air is cold and it will be under low load?
