Dell P991 suddenly get blurry
M
mfm
Guest
We have a little used Dell P991 19" monitor that we came into possession of a few days ago. The picture is bright, the text is crisp, and the colors are very good. My wife likes it a lot.
The problem we are noting is that the text and graphics can get blurry (fuzzy) all of a sudden. It has happened twice in two days. Turning off the monitor and turning it back on corrects the problem, so I am fairly certain the problem is the monitor and not the video card (Radeon 9600np, Cat 4.2, WinXP Pro).
The resolution is set to 1024x768 and the refresh rate is 85Hz. Is it possible that this monitor can't hold the higher refresh rate? I have tried up to 100Hz and the P991 can handle it. I am just wondering if this particular monitor is failing and if this problem can be corrected.
dude i have the exact same monitor, i posted a few days ago but no responses, exact same thing happens to me and its very annoying
I keep thinking that this is possibly an overheating problem, but my family used that monitor tonight for close to 4 hours continuous, and it did not exhibit any blur or fuzz. This is in addition to the 2 hours we left the monitor on while going out to dinner with the screen saver/lock on.
My only other thought is that some form of graphic output is causing the monitor to become blurry. Is that even possible?
I am probably jumping the gun here, but we have not seen the problem since early yesterday afternoon. One thing I did when it got blurry again was to disconnect the video cable and reconnect it, thinking that might solve the problem. It didn't (rebooting did), but after that point the monitor has worked flawlessly. My wife used the system all day today (job searches, resumes, emails, etc.).
Could an improperly seated video cable cause this problem? What about a defect or crimp in the video cable? Unfortunately, there is a fixed video cable on the monitor, so trying another one is not possible (unless I can rewire a new cable to the inside, something I haven't done before).
I've had this problem occasionally with my P991 as well. It only seems to happen about once a month or so. Turning it off and then back on almost always fixes it. I've never really speculated as to the cause of the problem since it happens so rarely.
On a side note, this monitor does seem to be susceptible to interference from other nearby devices. I've had a lot of trouble with the image shaking at certain resolutions, but moving the monitor away from everything else on my desk fixes the problem. It may also be the case with the blurriness.
to mfm, its not the video card, i know that for sure because i ran my sister's lcd on this comp continuously for 48 hours, nothing was wrong with it, but with the p991 there was, its just the monitor, damn those craptacular montiors
Well, I switched monitors when it last went bad two days ago and that monitor was fine, so I would have to agree it isn't the video card (at least not directly).
You will notice, however, that I said "two days ago". Ever since I reconnected the video cable into the video card and spread out any bends in the cable itself, we haven't had the problem. Which begs the same question I asked before: can a damaged video cable cause the problem we saw over the weekend?
