Dell P991 Repair
zackboll
Ok so I found Dell 19 inch CRT trinitron monitor by the dumpster today. I brought it back up to my place and noticed that one of the pins to the plug had broken off. Since it is a dell crt, one end of the vga cable goes into the plastic casing and the other end is the male plug. In regards to repairing it, am I going to have to splice a new male head onto the vga cable, or does the cable plug into a board inside the dell plastic casing so I can just replace the whole cable?
thanks,
Zack
nevermind, its pin 9 which is n/c
the monitor works, the color just all funky and their is diagonal lines running through the screen
