Dell P2310H (Eyefinity Viewing Angles)
chronox12
Can someone who is currently using the Dell P2310H monitors in Eyefinity please post pictures or even better yet a video of the viewing angles. I want to buy these monitors for my setup but I've heard horror stories about using TN panels in Eyefinity. These fit my current budget since I can't find any IPS monitors with 1080p or higher resolutions for $300 or less. Thanks in advance for the feedback.
Check out these:
- http://www.youtube.com/user/chadsmith20#p/a/u/2/hOF3Nxr3R-E
A user page with some vids of racing games, you can't see all three monitors unfortunately...
Hope this helps. As far as I can tell the angles aren't that bad in landscape. If you want to go portrait mode, I would suggest waiting for the HP ZR22w which should fit right into your price range...
Edit: removed the first two youtube vids as they were showing u2410 displays, thanks to wagsrules to point that out!
That HP ZR22w monitor looks like what I've been waiting for indeed! Now just to hold out for the arrival of those 6 port Radeon HD 5xxx video cards. Thanks for the information.
Are you sure? Cause I could have sworn that guy mentioned in another one of his videos that he was using 3 P2310Hs. And the colors on the right monitor seem really washed out to me to be a non-TN panel.
He state resolution of 5,760 x 1,200. That is 3 1920x1200 lcds. Also if you look the monitor has a silver stipe on the side. Only the u2410 and 2209wa have this the the p series are all black.
The third link is the p2310h. I know the camera is at a different angle but look how much more washed out the side monitors look. The center is much brighter. Obviously those are tn.
You're absolutely right, I hadn't noticed the resolution in the video description. I've removed the WoW link from my original reply as well as those showed the same setup.
Back on topic, I did find some screenshots of P2310H eyefinity setups:
- http://www.redflagdeals.com/forums/9928250-post128/
- http://www.overclock.net/7654950-post29.html
The last one is from blksnake, I believe he's a [H] forum member as well.
P.S.: yes this time I double checked they were P2310Hs ;)
