Dell Optiplex GX260 - Need advice
mokkapoop
My work is looking to get rid of line of Optiplex GX260's. They are $50 each. I only want one. Does anyone know the exact specs of this machine, its the mid-tower case type. I have some DDR 333MHZ ram, and a P4 2.8GHZ 533Mhz fsb chip I want to put in it, but will it go in it. Please let me know guys, thanks!
I'm not sure of the specs of THOSE machines, but at my POW (place of work :D) we have some Dell Optiplex GX260's with the following specs:
  • 2.4GHz or 2.6GHz - P4 Northwood Socket 478
  • 1GB DDR2100 266MHz (I think this is right tho it could be DDR2700)
  • 250W Dell Powersupply
  • Onboard Video/Ethernet/Sound
I can give you better specs if you want, just let me know and I'll write them down @ work sometime.
I think both your processor and ram would work fine, though I'm not 100% sure.
Take a chance, for $50 you can't go wrong! This would make a decent HTPC IMO.
I'd buy one! ;)
I'd buy one! ;)
Is the motherboard a small motherboard? I would like to take the motherboard out and put it in a small case. Do you know if the CPU I have will fit in it? This is kind of the selling point for me, because if I can, then I will buy it.
You can't do that if it's the small form factor. They mount on trays with non-standard mounting points. Makes swapping out a motherboard a 5 minute affair, but don't expect to fit them into another case without some work. The GX260s and 270s are the ones with the capacitor problems, so make sure you check the caps on it before you take it home. I believe you can still get the motherboard replaced if it has problems. The way to tell is if it randomly goes into standby (amber light on the power button) and won't come out without unplugging the power cord.
Guys, thanks, I already knew about the capacitor, what I am asking is will my P4 2.8GHZ 533mhz go into this motherboard?
Run CPUZ on them and find out what chipset its using, cpu, and ram... that will give you an idea if it'll run your parts.
DELL GX260 Documentation
I have one too...
How much do you want for one if you purchase a few more for $50 a piece?
GX260's are NOT afflicted with bad Nichicons.
GX270 & a few 280"s are affected.
http://warrantypartsdirect.dell.com/us/program/T1910000.ASP
