Dell Optiplex 790 and new case power button issue
I have purchased an Optiplex 790 and I put it into a new case. The problem is that it has a connector that's one single connection for all the front panel stuff including power button. Anyone know how to get it working or specifically the layout for the other buttons too? I can still fit the power connector on these pins just fine, but can't figure out which is which.
edit: Nevermind figured it out, in case anyone else needs to see this it's actually a 5 prong connection in the top right. You can put a standard 2 prong power switch connector at the left part vertical and it will work, although you still get a warning when you start it that there's a power cable switch failure.
