Dell Oem Mobo front panel pinout
Soarin
I believe this mobo is out of a dell xps 400, its a dell 0yc523 mobo with the stupid 40 pin front panel. I found some info, but nothing that for sure states which pin is which, (100%) sure. Does anyone know which pins are the power switch? I am trying to make a headless server but cannot boot the mobo as I am not sure which pins to short.
I tried 23 and 27, nothing, also tried 23 and 28. No bones. both versions of the pinout show 23 as the constant pin
Also seen all of those post, still nothing. The mobo gets power but will not "boot" It did work when I pulled it. The green status led is on, pins 27-26 causes the mobo to flash. This is a non standard psu I am using.
That information would have been better served upfront. Sounds like the mobo is toast or the PSU you're using is toast. You don't have an unknown pinout issue, you've got bad gear.
Well I am leaning more towards the PSU because the mobo worked when I pulled it. Although my psu tester shows good voltage for the PSU also, but thats not under load. Oh well.
some dell mobos require a pair of pins on the front panel header to be shorted together so that the motherboard "knows" the front panel is attached properly
