Dell NX3100 vs MD3200i
Jay_2
What is the difference between these two products? Does anyone here use them?
thanks, I still dont really see a huge difference in these products to be honest. It looks as if the MD3200i is a slightly better option though.
Looks like the NX3100 is running Windows Storage Server 2008, so it's primarily a NAS, but you can use the MS iSCSI target to emulate block level storage.
If you're looking for an iSCSI storage solution I would go with the MD3200 since it is true block level storage (I think). I know the MD3200 isn't the best performer and I'm guessing the NX3100 would be worse, at least for iSCSI. The MS iSCSI target software isn't the greatest.
Or you can buy a JetStor for half the price with more storage and higher IOPS without having to pay for annual support and with the option to load your own disks rather than having to buy Dell disks which are marked up by 30745639566465% when it's time to increase capacity.
I dont think JetStor have anything in the UK sadly.
EDIT
no I have found that they do have a UK office!
I have also been looking at just getting a VNXe
