Dell Level 3 Switches - GUI?
marley1
Do the Dell Level 3 switches have a GUI?
What about the Level 2 (not web managed ones, the 55 series).
layers.... not levels.
and yes, even the higher end dell layer 3 switches such as the 6448 have GUI's.
Learn the CLI and get a serial cable- some switches require CLI for initial config (IP and user), others require CLI to reset, and it is usually faster for all of the above in any case.
I assume i can pass VLAN over the Fiber?
Pretty much I need to make Port 1 uplink to main router. Port 2-22 part of VLAN 1 (192.168.10.x), Port 23-24 part of VLAN 2 (192.168.11.x) and then need the be able to pass VLAN1 and VLAN2 over the fiber to the next switches.
Is this possible with this switch?
which switch in particular?
If it is a layer 3 switch then yes.
Fiber is just an interface and you should be able to pass 802.Q traffic across it just fine.
Dell managed switches have all a WEB Gui but I recommend using them in CLI if you can.
I encountered some issues with the GUI and none with the CLI on my 3,5 and 6 series switches I have in the field.
