I recently purchased a used dell 2007wfp lcd from ebay. I've checked the amount of used time by holding the menu button while turning it off. It has 1540 hours of use; ac power is 50 and soft key on is set to 55. It seems to be in very good condition...I bought it from Tigerdirect ebay outlet store.
Anyways, anytime I turn on the monitor or it wakes up from sleep/powersave mode...it flickers for about 10seconds...especially noticable on the whites. It then goes away and is not a problem. I notice that if the monitor has been on for a while and just goes to sleep....I can awaken it with no problem, but if it has been off for a while....that is when I get the flickers as if the entire screen is shaking. I have a atix300se video card with the newest catelyst 8.4 drivers.
my previous lcd was a 17 inch dell which did not have this flicker problem. I think this would rule out the video card. Both lcds are using the dvi (white) input
What do you guys think seems to be the problem?
Thanks,
Thanks,
