Dell laptop charger replacement
Wrench
Well my laptop charger decided to let out the magic smoke, followed by the magic sparks, followed by the carpet fire.
Soooo I need a replacement. Looking on ebay I'm finding a ton around $20. How good are these. I realize you get what you pay for. Dell's is $140. Should I just go with dells?
You should be able to find dell branded ones on ebay for under $30.
I take it your are Out of Warranty on the notebook? The battery is one year, but the rest including the charger is covered by the regular warranty?
Trust me on this: buy genuine Dell but get it on eBay (I just did, check my thread about "Laptop eats AC adapters, what to buy?") My third-party adapter has decided it will no longer charge the battery after only a couple months of use. No, it wasn't a BIOS update (where Dell says "You're not using our stuff, no charge for you." Dunno if they do that but it certainly wasn't what caused my problem). This third-party adapter has enough electrical tape covering its fraying wires to strangle someone. It's that crappy.
Yeah warranty ended a long time ago. It's an old M170.
Cool thanks for the heads up.
I disagree about the 3rd Party Route. Obviously if there is tape covering wires, that is an absolute horror.
But I bought a 3rd party battery and power adapter from the same company and they are working just as good as the original ones I had. The name on both is Denaq. I have an Inspiron 9200 and I got the charger and the battery for less than $100. When I was using Google for shopping results, some of the prices were nuts. One had me at $240 something for everything.
So I think that there are definately bargains out there. Definately be careful though when you are shopping for a company you aren't familiar with.
