I have a Dell Inspiron 530 with an Intel Core 2 Q6600 cpu and with a Dell 0FM586 motherboard with the P35/G33/G31 chipset. This pc has been doing sporadic lock ups and I am leaning toward something going out on the motherboard. Replacement boards for this are like $120 - $150. I was just going to order a new motherboard from Newegg for around $40 with a P35/G31 or a P35/G41chipset and wondered if the Dell Windows XP Pro that is installed will be looking for a Dell BIOS and not boot up? Or does it just search for the BIOS when you are installing the OS?
I have done something similar to this with custom built systems I have built in the past when I had to replace a motherboard, Windows XP will usually work just fine, because it detects the same chipset and all. But I was not sure how the Dell OS would react.
