Dell Dimension 2300 questions
KoolDrew
We have an old Dell Dimension 2300 as the "family computer" and today I went to dust it out and somehow the heatsink seemed to have broke off of the bracket. Both pieces that the heatsink connects to on one side broke right off. I guess it was having overheating problems previously, and I guess that is why.
So, I need a new bracket before I can even put a heatsink on. Where could I get this? While in the process of doing this I figured I'd get another heatsink and lose the duct Dell puts in it. Any suggestions here?
Also, currently it has a P4 1.8GHz CPU and 384MB of RAM. All my family uses it for is browsing the internet and stuff like that, but its current specs aren't cutting it. Should I buy a 512MB stick of RAM and throw it in there? Where could I buy cheap RAM? It seems like everything compatible with it is really expensive. Like $80 for only 512MB. Or would buying RAM just be a waste of money and they should sell it on eBay and build a cheap new system? Also, if you guys think it's best just to upgrade it case modding could always be fun. :)
In all honesty its about ready to go in the crapper,parts for a system that old are to expensive and are not justified to spend that much for it.If your not looking to play games with it really its worth it just to go to your local comp store and buy spend 350 to 450 on a brand new tower probably can get a lower end dual core for that much,and if you need a lil graphics processing power just get a 8600gt or gts and install it yourself.Thats what i would do
Eh... I'm using a Dimension 2400 right now for simple web browsing and email. Its not that bad. However, since yours is broken, I would simply upgrade if you couldn't fix it for cheap. Is this what you need? If so, this looks very similar, but much cheaper, lol.
If you were to upgrade the system, what would your budget be? There are some good dell deals you could cash in on.
