- Sep 15, 2004
Those antec tri speed fans are nice. Got 2 of them that are going into a watercooled e-machine I am working on... Nothing in it is an e-machine other than the case.
Yeah, it had lame overclocking ability, but i used a fan-less heatsink with the original exhaust fan duct to keep it quiet. A 2GHz Athlon XP was overkill for a HTPC anyways.Silversierra said:Oh, the mobo you used, does it have oc'ing options? I guess it doesn't really matter though, I'm looking for a socket 478mobo. It says your mobo is agp 4x, can it use agp 8x cards?
It looks like you didn't use the front usb, It doens't look standard, is there any way to get it to work?
pxc said:Yeah, it had lame overclocking ability, but i used a fan-less heatsink with the original exhaust fan duct to keep it quiet. A 2GHz Athlon XP was overkill for a HTPC anyways.
I was too lazy to hook up the front USB ports. I wasn't using those anyways and would have just rewired it like the front panel connector.
Silversierra said:Ok more pictures. Here's the front usb pcb. Odd, recognize the name on the usb ports?
I don't know which wires are for the mic and which are usb, it's a mess.
[.IMG]http://www.alienhax.us/uploads/dellusbfront.jpg[/IMG]
[.IMG]http://www.alienhax.us/uploads/topviewusb.jpg[/IMG]
I did, it doesn't have the traces on the bottom, they're on the top and they're hard to follow. It seems the color red it usb power, black is ground, yellow is data-, and orange is data+, but that's a guess, I could try it, but I don't want to fry my jumpdrive lol. There's only 1 red(assume power usb), which is odd, shouldn't there be 2 power(one for each port)?SpangeMonkee said:flip it over and follow the traces.
Silversierra said:k
The other 5 are unused. Like you guessed, 6 wires are used for audio and 9 wires are used for the 2 USB ports. 3 would have been used for the microphone + loopback.DarkMonkey said:Why does that PCB have so many wires? A dual USB port header only requires 9 pins, and 3 for the speaker connection, add in an extra three so they can run the signal back and make the connector short the signal, and you're still only at 15 wires. I count 20 on the connector. What are the other 5 for?
What would that help? Which 5 are unused, there are 19 wires, 6black, 2yellow, 2orange, blue, brown, lt. brown, red, 2green, pink, white, and gray. What colors are usb? I'm guessing red, black, yellow, and orange. What colors are headphones? Does dell even use standard wire colors?pxc said:The other 5 are unused. Like you guessed, 6 wires are used for audio and 9 wires are used for the 2 USB ports. 3 would have been used for the microphone + loopback.
Silversierra: you need a multi-meter.![]()
so you can trace a pin on the circuit board to a wire.Silversierra said:What would that help?
Captain Colonoscopy said:Nice work.
Now you have to paint the other side panel to match.![]()
Silversierra said:"what days does fedex ship? Do they work on saturdays? How 'bout mondays?"
Anyone know?
Anyone know?
mohammedtaha said:They don't ship on the weekends. The parcels move on the weekends .. So anything shipped on Friday or the week before can still get in on Monday. You can't ship something out on the Weekends though, nor should you expect anything on the weekends.Although I'm sure there are some services that allow that.
