Dell D420 hard drive replacement questions.
leodaso
I saved a Dell Latitude D420 from making a trip to the dump. It is in great condition, however the hard drive has failed and is unrepairable.
I've been tossing up ideas for replacements, unfortunately it has the uncommon 1.8" ZIF/PATA interface. I don't want to buy a used hard drive, and from what I have researched, drives that have been PROVEN to work with the D420 are no longer available new. I don't need much hard drive space, and would rather have a FAST drive. It would just be used to surf the net and setup/test small networks and wireless routers. I've replaced the Wireless NIC with a Intel 5100 that I have laying around and it works great (with a bootable linux cd).
My question is this, I purchased this. It is a ZIF/PATA to CF adapter. The pinout is the same that is on the failed hard drive. I am thinking about buying a 32GB 400x CF card for it. In theory would this work? Has it been done? Or is there a SSD with this ZIF/PATA interface I should look at instead?
Thanks for any info.
