how do I check the time usage thing? I can't find it on the menu
what is "flickering" if I may ask?
Thanks! well I don't know If my 2007WFP "flickers", but I moved from CRT to LCD, and The white that I see isn't a complete white and there seems to be a lots of black really small dots, I asked here a week ago about this and someone told me that's how LCD works, so I had a little relief, but now people say that they don't have flickering, what does it mean? they don't see white dots?..To see the service menu(panel info on top line):
Turn off the monitor.
Hold down "menu" and the "+" while powering up the monitor.
When monitor is fully powered and the input graphic disappears: release "menu" and "+" then press the "-" button
From Wikipedia:
Flicker is visible fading between image frames displayed on cathode ray tube (CRT) based monitor. Flicker occurs when the monitor's CRT is driven at a low refresh rate, allowing the screen's phosphors to lose their excitation (afterglow) between sweeps of the electron gun.
Since flat panel displays use Active-matrix liquid crystal displays which use a transistor for each pixel make the pixel keep its state, they do not flicker, at least not based in the screen update rate. They may however show flicker from the backlight, but it should normally be refreshed at rather high frequencies.
Basically the screen goes black before it displays again, like an eye blink, quickly disappears and then reappears again.
Everyone still getting 2007wfp S-IPS panels, are you ordering them brand new? Refurbished?
What happens if you get the PVA panel? Can you return it?
Thanks for the explanationYou are talking about two seperate issues here. One is flickering, the second is the dots.
Flickering generally occurs when your eye / mind interperts a poor sync or refresh rate of the screen. The lower the refresh rate the greater the chance that you will see the monitor flicker. Some people are more sensitive to lower refresh rates than others. Flicker sometimes can also be seen when using your pereferial vision (like looking out "the corner of your eye"). You can tell if your monitor flickers if you catch yourself thinking "Did I just blink or did my screen go blank really really fast". So in short, flickering has nothing to do with the "dots".
Now about those dots. I think what you are describing is the effect that the anti-glare matte on the monitor is having on the display of images. The way the LCD panel works is usually different than most CRT monitors so that may also take a bit of getting use to. I don't think anything is wrong with the monitor.
One thing that may be wrong is if you are not running in the monitor's native resolution. If you aren't running in the native resolution then your image quality will be lower and some of this problem may be from that. If you are not running in 1680 X 1050 then you should try and see if that helps.
My money is on the reflective coating.
Is there a more reliable check if there is flickering?
...anyone can tell me how to check for color banding issues or backlight bleeding?
Well I just got my 2007wfp today. It's a S-IPS panel (RT803) A04; Made in Mexico. Unfortunately, it has 1 dead pixel >_< I called Dell for a replacement and it should be coming next week.
wow good for u freeze888....I have a stuck pixel on a black background...is there any way I could fix it? I have heard about stuck pixels that can be fixed using some methods...tried the UDPixel for few hours...didnt work...and also the JScreenFix applet for hours too but it didnt work either....should i try pixel massaging? I am pretty afraid I might cause more stuck pixels to form up....If not, I hope to get my panel replaced...Their dp policy here is like 5 dp..I hope they change for 1 dp...
Received my 2007FP today in Canada rev A04 and it has panel HN210 and has purple tint at angles indicting S-IPS.
This is good news since I will be using it in portrait mode alongside my 3007WFP-HC when it arrives.
Good to hear this. I'm waiting for mine since I jumped on the 70$ deal (just posted above my post).
Keep in mind, I was reporting that my 2007FP (non-wide) monitor was IPS. However, it seems all WFP's are also IPS so you should be fine. That is an awesome price!
Got my 2007WFP last evening as well. It's a A04 and the panel is S-IPS confirmed by the purple hue and the service menu show RT803. I'm happy and everything seems flawless (didn't have time to check everything since I need to go to bed early).
I assume that A04 is 99.9% guaranteed to be S-IPS so it's a good thing to request this revision when ordering one to have the best chance of getting the right panel. This is what I did when I ordered mine after hearing that A04 were all S-IPS so far.
There is however a issue, which might have a easy fix, but when I plug the DVI cable to my computer, the monitor doesn't receive any signal. I'm upgrading from a old Samsung 700IFT 17" CRT so I assume there is something I need th check or update to enable DVI. VGA works perfectly fine both in Windows XP and Ubuntu 64. I'd love to hear what I need to do to fix this, knowing I'm running the LCD from a XFX 7900GS.
This may sound stupid but I'm going to ask anyway. Have you tried selecting the DVI input mode on the monitor? It is input number 2. You can cycle to it by pressing the button with the arrow and box.
