Much more noticable in person?Also much more noticable in person.
I already find this pretty ugly, i don't want to even imagine what it may look like in person if it's much more noticable.
Well, we got the other one in. This one came from the Nevada warehouse, RT803 S-IPS panel. Seems like everyone is winning nowadays.
Edit: Forgot to mention, no noticeable problems like banding or dead pixels on arrival. Looks really good!
That's really good newsWell, we got the other one in. This one came from the Nevada warehouse, RT803 S-IPS panel. Seems like everyone is winning nowadays.
Thanks ArLo.I'm really gonna need all the good karma i can getaguire, I don't think you will be disappointed. I am very impressed with my second 2007WFPb which doesn't have any dead pixels, as I experienced with my first. DELL has promptly responded and replaced with no hassel. Other than the small amount of flickering when I visited that website, I cannot reproduce it in shades or solid colors. I wish you good karma with the DELL Lottery and 2007WFPb tranquility, LOL!![]()
Anyone buying these(2007FP 4:3)? It seems like the WFP lotto has swung back to S-IPS, I wonder about the FP, it has been mostly PVA, but I really prefer the 4:3 size, but I won't buy unless there is a reasonably chance of S-IPS.
Snowdog did you give up on LG L2000C already?, I've got another conirmation today it is S-IPS....
I'm still not sure this flicker isn't something that can just happen with some patterns and is benign.
toastyx posted a site a few days ago with tests for induction.
Down to the bottom of the page there are 12 different tests. I don't get the same 2007wfp flicker on an NEC but I can get some flicker on other tests but these flickers are not considered unusual:
From Site:
http://www.techmind.org/lcd/
"The following test patterns deliberately excite only one polarity-half of the inversion pattern for some common schemes, and one of them should cause your screen to flicker. This is not a fault with the screen, but enables you to find out which inversion scheme your screen uses..
The inversion pattern for any given screen will inevitably flicker to some extent and is not a fault. If it really flickers a great deal then it may indicate that the common-electrode voltage has not been set up properly. In that case you might also perceive a "dot crawl" effect on plain colours of medium brightness. A grossly mis-set common-voltage will also make your screen more susceptible to temporary 'image sticking' problems.
Common-electrode voltage can sometimes be adjusted by means of an internal preset, or on a manufacturers' configuration screen (adjust for minimum flicker on the inversion-pattern) ...but doing so would almost certainly invalidate your warrantee. Typically, with the optimum setting, the centre of the screen will have minimum flicker on the inversion pattern, while the flicker will increase somewhat towards the left and right edges. If there's a distinct minimum anywhere on the screen, then the setting is pretty close. Note also that the optimum setting is likely to drift over the life of your screen, and may be slightly affected by temperature and the greylevel of the test pattern.
Any adjustments are made at your own risk!"
Yes, but the point is that on DELL's forum most people mentioned this issue when they reduced the brightness to 12-15% for photo editing.And a lot of people didn't mention any problems, even after i asked them to visit the link you posted.No flickering at all according to them.Reducing brightness is perfect way to ruin colors and make calibration unusable - Doing so its like avoiding problem but making your S-IPS look like 6-bit TN![]()
I don't know Glengoyne, that's what i've read on DELL's forum.When someone mentioned he didn't notice any flicker, the guy insisted that he should reduce the brightness in order to notice the flicker, so he wasn't trying to defend DELL or anything![]()
I don't know what's going on, on DELL's forum, but many 2007WFP owners on different forums i asked, didn't notice any flicker.So if someone doesn't notice anything, why bother trying to![]()
I'll try to find the thread for you.![]()
You really are determined not to let us have a good time using the 2007WFP, aren't you?Well, there`s two kind of flickering; another is on whole screen area - another is this what I`m talking about - 1/3 part of screen. You can easily check the dates on Dell`s support forum; first problem is older - mostly on revisions A01&A02, "new" flickering is on A03.
If someone does not notice the flickering - it is just good for his/her. Everyone does not know what to look for. And hey, someone even might have wooden eye![]()
I'll go with the flow in this one.If most people really like their 2007WFP and highly recommend it, then for most people it's fine.![]()
Oh,so could this "problem" be more widespread in monitors manufactured in a specific factory then?
Not everyone is a technical engineertrueEveryone is not interested in technical details or does not care about getting 100% perfect product - or they just accept products what they are like
Correct, but you never know what could go wrong in the assembly line of a factoryMight be, but we have to remember that Dell does not make single panel by themselves, they are bought from Samsung or LG-Philips.
Actually, we don't really know on how many monitors and under which conditions flickering appears.Do we know if this flickering ever appears in regular use? Or only on a test screen?
Because I have never seen it on my workstation. In my case, at least, the flicker issue seems moot.
In that case, i would send it back.For me Its annoying as hell in and BF2, and a lot of sites I visit have background colors that flicker. I also watch a lot of anime and the flicker is noticeable there as well. If it only flickered on a test screen I wouldn't care.
Just got mine from dell yesterday... and its a SIPS A03 made in czech republic ordered it from sweden
made in december 2006? same batch as mine was. You can check the details with moninfo.exe.
Do I dare to ask; what about the flickering? this answer might give us more glues...
