Dell case.. question
Porphyria
Well I have a dell 4550, and ... well, its a long story as to why. But anyways, I am sick of this p.O.S. motherboard... and I was wondering (seeing as I don't know enough about dell), if it is possible for any motherboard to fit into this case. Those monopolizing.. *******. Anyways, if so, what would you recommend?
If nothing, it's alright.. I am building myself an alienware-similar computer in a few weeks... so recommend a motherboard for that?
PS: I am using a p4 2.4 ghz
Dell doesn't mension a name for what form factor they use, so I don't know if they make mobos that would fit.
The case is a mini-tower but beyond that I have no idea what form factor for the motherboard they use either :(
in general even proprietary stuff made by Dell and Gateway are usually in standard form factor. After all, it is cheaper to use standard motherboard sizes than to pay the extra to get a special size.
Could you link to the case?
Now you said its a mini-tower - then the minatx form factor is prolly your size. - My suggestion - measure where the motherboard is located - length by width - and see what boards fit. (newegg.com and several other seller (not to mention board manufacturer sites) will give you the size of the board so you can match it with the case. Also take into consideration where the psu and drives (cd rom type) fit as the overhang for they may limit your choices.
Good luck.
Dell uses Intel boards so the form factor should be standard atx. However, you can't use the power supply, that's proprietary and won't work with third party mb's.
Sometimes however OEMs use crappy low watt power supplies. Look at the rating of the power supply to make sure that it will handle your newer components.
Example: HP often uses 200 Watt supplies.
Heed this - they "change" a few things around. It may "look" like a standard ATX connector going to the mother board...
Add a good Enermax to your shopping list.
Peace,
Tim
