Dell Cabinet worth $350?
imzjustplayin
I found a 42U Dell Cabinet that is selling for $350 (looks like the one on the dell website) and I'm wondering if it's worth it or not. I mean on the one hand I need a cabinet but on the other, I feel it's too deep for my room but because it seems to be a good value, I'm wondering if I should buy it anyways.
If it's something you see everyday, you should get one that you wouldn't be ashamed of when you look at it.
Unless you plan on racking Dell servers in it, then avoid Dell cabinets. Dell mounting rails have slightly different clearances on either side than normal 19" racks, and so Dell servers don't fit just right in many racks, and I'd imagine vice-versa
Also, $350 is not a steal at all for a cabinet. I regularly see them around $100 on craigslist locally
Well it's a modern dell cabinet. Are you saying that dell's 19" racks aren't really 19" at all? What about APC? I find it pretty odd that their racks really aren't 17" apart.. http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=04&kc=6W300&l=en&oc=becwsk1&s=bsd (Power edge 4210).
Isn't EIA the mounting standard for "standard" 19" racks? Does dell not abide by that?
The only thing I can think of actually is the whole mounting rail shape, it's like C shaped then [ shaped and it was in a faq somewhere and now I can't find it so I'm unable to refer to it unfortunately. But it was a picture with the different types of mounting rails.
I run Dell servers in non-dell racks and non-dells in dell racks. The biggest issue is that the Dell racks have square mounting holes. You need to buy the hole insert thingies to screw in the non dell systems. In addition, to put Dells in non-Dell racks you have to buy their line of "Versa Rails". So they aren't compatable out of the box.
So yeah, I'd recommend getting a non-dell rack if you are going to have varying vendors systems in there.
Would an APC AR203 at $250 be worth it? The guy lives about 50 miles from me so he wants to sell to me cause it would be semi local. It's in box.
Meh. I mean, I don't know what the situation is where you're located, but, at least here in Portland, used telco/rackmount equipment is available on the cheap, and you could easily get an enclosed cabinet for that price, if not cheaper. However, that being said, that APC rack isn't a bad one at all.
I'm in the bay area, however the guy says it's new. I have a rack already, but the reason I've been asking all these rack related questions is because the APC netshelter I have (got for free) is very deep and I don't believe I can use it in my situation.
