Dell 9200 fan plug jumper setting (experiment)
xcgames
I had my dell 9200 computer for over a month now, although I am happy with its performance, the fan is absurdly loud and produces so much vibration that the entire case begin to make noises.
I figured maybe I can shut the fans off and use quiet aftermarket in their place instead. The problem is dell uses some insane 5 pin plug for the fans, instead of the 3 pin that we're all used to see on aftermarket motherboards. I tried running the machine without plugging in the fans and the system held at BIOS everytime, require me to manually hit F1 key to proceed booting, which is very annoying.
Since there are no options in BIOS, the only way to do the trick is to complete the circuit and jumper the two +/- pins together, right?
Here are the pin setup on the dell, I'm thinking about jumping pin # 3 with # 4
#1- empty
#2- blue
#3-black
#4-red
#5-white
any further suggestions before I try this thing?
Nope, no suggestions, but a request.
If you try it, and nothing explodes, please let me know.
I put my kids Dell in a different case and changed the hsf, and I swear he has accused me of being a retard for over a year for not being able to figure out how to bypass the F1 step.
i want some expert opinions on a list of possible consequences of tapping red into black with a normal hard drive jumper. This is a rather expensive machine with conroe e6600 so if something frys it would really suck. then on the other hand, this noise issue must be taken care of.
