Dell 8100 Video Card
mactech
im need to upgrade video card. I want a Gforce but my powersupply is only 250w does anyone know the best card i could get?
The "250W" PSU in your 8100 is rated at:
+3.3V 14A
+5V 22A
+12V 14A
-12V 1A
+5Vsb 2A
(+3.3V & +5V Combined 140W Max)
which most manufacturers would call 330W. Your choice of video card is mostly limited by the speed of your computer, not the PSU rating. ;) That system uses a S423 Willamette P4. You should have no problem installing a Radeon 9800 Pro or 6600GT in that system. Even a 6800 or x800 would work, but it's overkill.
Powerleap sells an adapter for that system for around $50: http://www.powerleap.com/PL-P4N.jsp so you can put up to a P4 2.8GHz/400MHz FSB Northwood in it. (ebay has great prices on CPUs... use the coupon code CELEBRATE on paypal to save 10%.) It's up to you to decide if adding more than a video card upgrade to that old system is worth it.
I am going to upgrade tha CPU to 2.8 ihave heard of powerleap. I just didnt want to pay $150. for a new powersupply that will work with the 8100.
thanks
