DELL 3007WFP-HC Problem
YahonMaizosz
I have 2 DELL 3007WFP-HC in a Dual-Monitor set up.
The problem is that, 1 of them is perfect in every way while the other has (1) DEAD PIXEL and the "WHITE" looks like a "PALE YELLOW"
The "perfect" one seems to be brighter and more lively when compared to the "inferior" one.
Why is this so?? These are the very same monitors, how could there be such a HUGE different of quality???
Can someone give me the solution to my problem??:mad::mad:
make sure you set the color tone. When my 2407's are set to PCRED the white looks yellow. Also make sure to check your color levels.
How do I do that? There is no other button in the display beside the "Brightness" and "Power" buttons
You can't set color tone from the monitor with an older 30 since they don't have scalar chips. Go into windows and play with color until it looks correct. Or you could complain to Dell.
Easy. Switch the monitor around. See if it's anything to do with your setup or if you have an 'inferior' monitor.
I tried switching cables and DVI ports and still no luck. The "Inferior" monitor just display everything a bit more "Yellow". I had also tried theJScreenFix that is supposed to fix any "STUCK PIXEL" in a monitor, but still do not work for me.. Now I am sure that I am having a Stuck Pixel instead of a Dead Pixel since this 1 pixel can appear either "GREEN" or "RED" when placed on a BLACK background.
I believe that there is a way to fix Stuck Pixel right?
As for calibrating color, I do not know any other way beside going to NVidia control panel which still do not give me the same result that I want..:mad::mad:
