Dell 3007FPW + XBOX 360
roadster
Hi guys,
I just ordered a 2405 and it should be here in a few days. I bought it because I can play games on my PC on a big screen as well hook up the XBOX 360 to it. What I have been seeing recently is the reviews and photos of people's 3007 and it really dwarfs the 2405. It really looks like a hot LCD!
One concern on my half however, is it able to be hooked up to the 360 because the VGA adapter only supports just that - VGA. No DVI. Finally, there are no component connectors on the 3007. Correct me if I am mistaken.
Has anyone got the 360 with the 3007 running? Or better yet will the 3007 be revised with some much needed connections (VGA, Component)?
Thanks everybody.
If you want size, go for one of the 37" 1080P LCD TVs. I doubt the 3007 will support any other inputs, ever.
Looking at your pc specs in your sig, you're gonna have a hard time running games in native resolution on the 3007.
Also, if I am not mistaken, there is a DVI adapter for the 360 available somewhere.
I have the 2405 and I can say that 360 games look phenomenal on it.
Yeah I think you guys are right. Looking elsewhere may be a better option. Secondly, I would have to get a new rig with at least a 1900XT or 7800GTX to power games at native with a sub par frame rate.
