I will be doing occasional gaming....The price difference between 2709w and 3008wfp is $1100, so it's not even comparable. If you need 2560x1600 resolution, you have to spend that much money and go for 30". If not, just pick up 2709w and save $1100. I have 2709w, and it's a good monitor for me since I don't play games. I don't feel any lag for my normal usage.
So i was thinking of the 30"
Does the pitch size really affect u? Since it's 0.303, i think it will affect quite a bit.
The input lag will happen even when it's connected from GPU to Monitor?
I'm initially wanted a 27" but the 27" pitch size is 0.303 n i think it's not too good for overall usage.
