Up till now I have only printed-out on my color laser, images created on my Dell 2407WFP. Recently I had an image created on it reproduced professionally. Quite frankly, I am stunned at the unwelcome difference between the 2407 screen image and the professionally printed image, which latter is far denser, darker, higher-contrast and generally too-rich. (Then again, I have yet to try another printing service, thus, to test whether my printing service itself botched the printing.)
It would seem that my 2407 needs calibrating--but, the 2407 being permanently set to factory defaults, is un-calibratable. The 2408WFP, on the other hand, is--which tempts me to fork out for an upgrade. Its ability to be recalibrated aside, however, I'm wondering if the 2408 is in any other way(s) a much superior monitor to the 2407. (I'm not overly concerned with issues of image lag; my only real concern is 2-D image quality.) Do, for instance, the two units use exactly the same panel or is the 08 a real jump up in image quality from the 07?
Beyond that and if an upgrade is indeed called for I'm willing to consider suggestions for other monitors--having also, S-PVA or better panels. (I don't like the idea of edge-lit models like the Samsungs, since the very principle of it seems a disadvantage from the fully back-lit kind. Come on, AMOLED!)
