Has anyone else noticed a very faint vertical red/pink stripe on the right side of the screen? It's very faint, but it's driving me nuts because I can see it when reading text on gray backgrounds (which many forums have).
I managed to take a picture that shows the problem:
http://www.toastyx.net/red/red1.jpg
It's very hard to see in that picture. Running a color equalizer filter on the image makes it more obvious:
http://www.toastyx.net/red/red2.jpg
If you still don't see it:
http://www.toastyx.net/red/red3.jpg
As you can see, it's very faint in the original picture, but it really is there and not in my head.
If you don't notice it on your monitor, try setting your background to this image:
http://www.toastyx.net/gray.png
It's easier to spot if you view the screen with that background from a slight left angle and move your mouse pointer back and forth while following the mouse pointer with your eyes. You should be able to spot it with your peripheral vision as your eyes approach the right side of the screen.
I already got a replacement, but the replacement has it as well, so I wanted to find out if anyone else notices the problem before trying to get a third one.
