Dell 2405FPW problems
exe163
hi, I got this monitor not long ago and when i trying to put my memory stick in the left side of this monitor it doesnt read it, even when i unplug the usb connecting to the mointor there is only 2 unplug soud (which is the 2 working usb port under the card reader) anyone have this problem?
I had a similar problem with the 2005FPW. Seems that the built in hub is kinda hit or miss. It will probably just start working if you keep fiddling with it.
make sure you plugged it in all the way then connect the cord to an empty USB port on your computers board (or expansion slot whatever), turn the whole system down including the monitor and power the PC and the monitor on at the same time.
