Dell 2405FPW components questions.
vat
PIP - Is this only for TV? If not, what can I use this for?
Component video (Y Pb Pr) connectors and Composite Video connector - What's the difference between these two and what can I use it for?
S Video connector - What can I use this for?
I think that's it for now, I hope I can get these answers from you guys. Thank you so much.
It's usedfor DVI/VGA with PiP of one of the analog inputs (Composite, Component, S-Video) and vice versa.
Component splits the video signal between different outputs and provides better image quality than composite. S-Video does the same and also provides better IQ than composite.
Component > S-Video > Composite
I have to warn you though that the inputs on the monitor leave a lot to be desired. DVI straight up through the PC is much better than any of the other inputs.
