Dell 2405FPW + 6800 Ultra performance...
macrospect
I think I have decided on purchasing Dell's 2405FPW 24" widescreen LCD monitor. My question is does any use this monitor in conjunction with a single AGP 6800 Ultra video card. For some reason I cannot find any benchmarks using this monitor. I was wondering if any of you have a similar setup to this. If so, how well does it perform??
Thanks in advance! :)
1920x1200 might be pushing it. I play all my games at 1680x1050 with a 7800GTX and it still looks great.
I have no problem with running at 1680X1050, I was just wondering what kind of framerates people were getting.
Also what are a few of the games that you play?
I play CS:1.6 1920X1600 with my ATI X300SE just fine (got around 55-60fps). It lags a little when I see smoke. Otherwise, I think everyting is fine.
Great, my 6800 should be able to handle most of my games no problem. Ill just make to keep AA/AF at a reasonable level.
Also does DVI take a larger frame hit over VGA?
DVI has no effect on framerate what so over. What it DOES do is give the monitor a pure and unchanged digital signal from the video card, this optimizes colors, contrast, brightness and clarity that you loose using VGA cables because VGA cables are ANALOG and hence dince you have modulate and demodulate a video signal on a VGA cable, you loose quality.
DVI does have a lower refresh rate but the trade off is well worth it in picture clarity
This is my setup running Half Life 2 Lost Coast with both HDR and HDR off at 1920x1200 with 4xAA and 4xAF. The Non HDR ran at 40fps and then HDR was at 29fps when the screenshots were taken.
Its quit alot even for a OC 7800GTX so you will have to reduce quality settings to get playable rates depending on the games
Thank you for explaining that to me IceWind. I understand now. I did not understand why VGA and DVI were so different, but I know now.
Cant wait until I get my first LCD :D
Thanks for the screenshots. I knew I would have to jam the settings down a little lower, but I am sort of stuck with my AGP at this point, so I will have to make do with it- which should by no means be a bad thing.
Besides, I can do withough HDR in games, I like to play them just to have fun. half the time I am not paying much attention to the "eye candy."
