Dell 2405 USB Hub drivers?
GodSpeed
Does anyone here know where I can get the proper drivers for the USB hub in the display? Did the display come with the CD because I can only find the manual CD ;\
The HUB should work out of the box, if anything your mobo might not have the USB2 ports installed. Thats what happened to me but an uptade to windows fixed it :D
Actually, what happens is if it's plugged into the machine at boot, it takes about 2 minutes before windows actually loads. If it's unplugged Windows loads up instantly.
I have an MSI K8N Neo4 Platinum mobo, some others have been bugging out about this but there really hasn't been much discussion about it.
Does the delay with windows booting happen when you have no devices attached to the usb hub?
Try disabling the "boot other" or "boot from usb" in BIOS. I get the same behaviour in Windows, disabling these options in BIOS does the trick :)
I had problems with USB hub on 2001fp (high CPU usage), solved with some sort of winblows update, dont remember which one exactly :)
This is odd because I already disabled all unnecessary things in the bios, all other usb items don't bug out except for the 2405. I'll see if activating them will do the trick :p
