Dell 2405 Issues... warranty?
SadTelevision8558
I bought a Dell 2405 for my parents 2.5 years ago. They hated it. Other than the fact that it was a lot larger than their previous 17" miniature screen, they didn't like how the colors were crap, the backlight bleeding, the fuzziness of the text.... blah blah blah.
2 years ago I borrowed it for 2 weeks and I tweaked it a bit. I gave them my 19" which they deemed too small, and then after winter break was over we swapped monitors again. 2 years later I upgrade to a 2707 after seeing my 2 friends with 2707s. I saw one calibrated and it looked like sex and it blew my Viewsonic VP191b away. I thought I had a decent VA panel, but today's S-PVAs are still a lot nicer.
I went home this past weekend and the 2405 looked like utter crap. Not to mention, it flickers a lot before Windows starts up. I don't know why and I can't even see anything before Windows loads. I figured it was a thing with the graphics card so I hooked it up to my Dell Inspiron. Same deal. WTF?
Do you think I could warranty this piece of crap and maybe I'll get a 2407-HC? I know the 2407 has issues but seriously, I'm sure it's got a lot of improvements over the 2405. Plus my parents don't game or anything so I don't think ghosting is gonna bother them that much esp when there's major input lag issues with the 2405.
Well i have a Dell 2405 FPW :)
I liked it. The only problem though is it does not have HDMI. But if your not getting a bluray internal drive anytime soon i wouldn't worry about it. Prices are still expensive for those atm anyway.
The new 2408 WFP which is a 24'' S-PVA looks rather good. The specs are much better, and they also have HDMI, DisplayPort and DVI ( HDCP enabled).
You should probably use your warranty if your monitor is defective. Mine works great except for the fact that the power wire socket on the monitor seems to be very loose. When i knock the monitor a bit sometimes, the monitor will go off and it can be a bitch to try and fiddle it back into the socket to get the monitor to work. The monitor gets hot, although i do leave my monitor on for long durations.
Anyway that is my 5cents.
