james111 said:I don't have the monitor but I do have a quick question.... how does the 9 in 1 card reader work? do you have to plug in a cable from the monitor to the pc or is the card reader seperate i.e plug in a SD card to the monitor and it loads up?
The reader is built into the monitor. You plug the card into the monitor on the left side of the display.james111 said:I don't have the monitor but I do have a quick question.... how does the 9 in 1 card reader work? do you have to plug in a cable from the monitor to the pc or is the card reader seperate i.e plug in a SD card to the monitor and it loads up?
