munkle said:I have a 2005fpw, its just the previous 20" widescreen model, there is no tearing when I play. I don't understand how tearing is possible on an xbox 360 as far as I know the xbox 360 will not do above 60hrz and any LCD or TV will do 60hrz.
If that were so it should be best with a 1:1 image because it isnt scaling anything but applying the image to exact same amount of pixels the resolution is, and not filling the screen. Hmm.. oh well.darkswordsman17 said:I think its because of the scaling of the different resolution that introduces the tearing. Seems like the Faroudja chip on the newer Dell's is actually detrimental to the image.
PYROTAK said:So is the component still broken? Some side by side pictures of the component xbox 360 vs VGA xbox360 would be SO appreciated you would not believe it.
Orr said:How can you hook up via component to the 2007?
xenogears said:You don't cause it doesn't have any component inputs. Only the 2407 does.
