dell 2007wfp Dvi cable replacement
Nvidia101
what kind of DVI cable do i need for it? does it have to be 18 pin? I want to replace it because of the poor dvi cable they provide.....
If Dell gave you a DVI cable with the monitor, that should work just fine. If, for some reason, you think you're having a problem, you should post that instead.
yeah i think I am. Do you know the part number for the dvi to the 2007fpw ?
Yes the cable it came with is fine in most cases.
I have purchased DVI cables from monoprice.com with great success. Use a 30 foot cable for my projector.
Any DVI cable will work. The 2007WFP does not exceed the bandwidth capabilities of single-link DVI so it doesn't require a cable with all the pins.
do you want to recommend one or know the part number so I can re-buy the dell cable.
All DVI cables are identical in functionality and picture quality; since the signal is digital and not analog, it is not susceptible to electromagnetic interference like VGA is, so between cables the only real difference is sturdiness. I recommend you look at a cable from Monoprice, as I hear they have excellent prices.
