Dell 2007fp SPARKLE EFFECT?
Jim Gravina
I just received 2 of these monitors and they both have like a "sparkle" look to them with bright colors. My 2208wfp does not have this. Is this normal? Defect? If normal is it easy to get used to cause right now its ANNOYING. And why does it look like this?
Thanks
Jim
It's the anti-glare coating on the monitor, there's nothing you can do about it. Both the 2007WFP and 2007FP have that "sparkly" appearance. I personally found this and several other problems reason enough to return my 2007WFP, which was a fairly decent monitor otherwise.
Yes, it can be annoying, PVAs have less of the sparkle (I wonder what you would say about LG 30" IPS sparkle - the 20"-ers have less). There is some company that redoes the AG coating, but you are better (cheaper) off returning and getting a different model.
