Dell 2007 Question
tokidoki
Hi guys,
I'm think of buying 2 Dell 2007 monitor, but I have a few question that i want to solve before i buy it. My current graphic card don't even support it (Geforce 4400 TI AGP), that is why I'm buying the ATI X800GTO AGP card. What i want to know is, if the ATI X800GTO support Dual Monitor. I'm going to be doing dual monitor with the two Dell, so I don't kno if the Dell DVI Connector is going to match with the ATI X800 GTO card.
Can you guys please help me? or give me a better opinion
Thank you.
My Comp Spec:
Computer: 3.0ghz
Motherboard: Asus P480SE - Deluxe
Ram: 2gb
Hard Drive: 400gb
Graphic Card: Geforce 4400 TI
Yes, the GTO supports dual monitors, ideally it will have two DVI connections so you can run each monitor on a digital connection. DVI connections are standardized, you don't have to worry about matching connectors between brands. The only catch is if you're running at higher than 1920x1200 over a single connector, then you're talking DVI-dual link, and only newer card series have those connectors. If your card has two DVI-single link connectors, you will be fine. If it has one DVI and one VGA, you're probably better off saving your money and buying a single monitor.
