Dell 2005FPW
declain
I just put in an order for the Dell 2005FPW. Under 550, is it the best choice or is there something better out there? I went through a lot of the posts about the different LCD's and this seems to be pretty decent.
Any suggestions against getting this particular model? Is there a much better one out there?
Thanks
S
is that in canadian dollars? cause in america its like 463 off the dell site, i got one and its awesome id say go with it, i havent found any other comparable wide screen monitor.
Post should have read: Just ordered one for 463.... But, under 550.00 - 600.00 (as a cap), is it the best?
Anyway, thanks for your suggestion. I assume the brightness issue that some people have had does not seem to be a problem?
Thanks
Steve
