Hello all,
I'm having an issue with my new 2005FPW LCD monitor (1 Day old). It seems to be blurry when there is a lot of motion in HL2, UT2004 (these are the only ones I tried). For example in HL2 the water hazard level, when I spin around in the Air Boat there is a water tower in the distance the becomes blurry. When I stop it's clear. I wouldn't say it's ghosting because I am not seeing double, but it's just very blurry. It also happens to objects when they are near such as a wall.
I have a 2.4GHZ Intel Proc with 512 Megs of ram, ATI 9700 Pro card. It's fine with my 19 inch CRT Trinitron, so I wouldn't imagine that it's an issue with the PC. Here is the setting I used to test with.
LCD
Using DVI interface.
1280X768
Aspect 4:10
4X Antialiasing
Vsync Enabled (also in windows)
Everage frame rate 50-55
I tried switching to the VGA interface but it made it worse. I also changed the resolution to 1680X1050 with no luck.
I also suffer from the backlight bleeding issue. Also had 2 stuck pixels.
Is this normal for it to have a blurring effect in fast moving games or could I have a bad monitor?
Other than that I love the monitor.
Thanks In Advance
LCD
1280X768
Aspect 4:10
4X Antialiasing
Thanks In Advance
