Dell 2005FPW and flashing red pixels
DeepGrey
I have a Jan Rev A01 monitor. I've had it since about the end of Jan and it came with very minimal backlighting issues and not dead pixels.
All of a sudden when I get home and turn on my pc, I notice flashing red pixels all over the screen. It seems apparent to only certain colors. When I have a google browser up at full screen, it doesn't show. But when I have my desktop up ( i have a dark black background) there are patches of red flashing pixels in light spots surrounded by black. I took a screen shot and pasted it into paint. The funny thing is when i scroll up and down, the red pixels follow the pasted background. Also when I play WoW, it ges horrible. Reds dots all over in certain areas, mostly in white colored areas.
Has anyone had issues smiliar to this. The funny thing is it only appears on white is blended in with dark colors. Any cause that could have made this happen? It's a little irritating that I paid almost $600 for a nice monitor and for it to start acting up.
Should I try to get a replacement for this? There is a 1 year warranty on this I believe. arg!!! any advice plz.... :(
(Could someone show my how to post a screen shot of a widescreen desktop and what I need to lower the resolution for it be be viewed on a thread so that I can show the pixels, thanks)
If it really is a monitor issue, you won't be able to show it using a screen shot. You would have to use a camera and take a picture.
If i'm interpreting that correctly it sounds like a video card problem. Please try another monitor on your video card and see what you get. Also if you can post the screenshot here and we can see it then the monitor is ruled out.
You could try some updated drivers for the card but it could be a slight hardware failure. Your not overcocking your video card by any chance are you? The fan is working properly?
if you have an ati card, go to options and click reduce dvi frequecy, there is also another option related to display corruption ..try it!!
Thanks for the replys. I'm actually running a MSI 6600GT stock. No overclocking on my pc what so ever.
I managed to fix the problem :D . All I did was reseat the DVI conector on my video card. Crossed my fingers...wala ... no more red flashies. That solves that and if anyone has the same problem... try reseating the DVI cable. ;)
