Dell 2005fpw/360 owners...
Circuitbreaker8
Quick question...i've always ran my 360 at 1280x768 since it looked the best on my Dell 2005fpw, but what resolution do you guys run it at? If I try 1280x720 it becomes SUPER bright ( to the point where I cant even adjust it correctly from the monitor ) and if I put it at 1080i, I get a small black bar on the side, along with the ones on the top.
I run it at the highest (1366x768) with the monitor set to aspect ratio lock, seems to work pretty well. Honestly though I haven't fiddled around with it too much.
I go 1280x768 because it looks the best theres no point going over that cause xbox 360 games are in 720p and then just scaled to other resolutions, why not try to keep it as close as normal, btw 720p looks like ass on mine, but 768 is awesome, i havent found a difference between 1280x768 and 1366x768 yet so im going with as close to 720p as possible.
Yeah if click the menu button while playing a game, you will see it is set to 1280x768, so theres no point at using 13.
I also get the same problem for 1280x720, it's bright as hell.
One question guys, do you get a lot of jaggies in PGR3.... it's ridiculous how jaggied it is, especially when other games look more or less antialiased.
Yeah, its ashame really. But I use the interior view 95% of the time, so I dont care lol
