Dell 2001FP vs Sony SDM-HS94P/B
hyperchao
I know it's hard to compare two monitors of different sizes, but they're about the same price. Let's assume that I can get both of these monitors for about $670. I don't think that the extra inch on the Dell will make much of a difference for me. I'll mainly be using this for gaming, so I was wondering how the 16 ms refresh rate compared with 12 ms. Also, how's image quality on both?
you can get the 2 monitors for $670?!!! :eek: Please do share.
Oh, and I was just wondering. Since the DELL has a tv tuner does that effect your graphics card performance...for say gaming, video editing, and 3d work?
Normally an extra inch may not make much of a difference in screen size, but in this case you are talking about two completely different native resolutions 1280x1024 vs. 1200x1600.
This will make a huge difference with issues such as text size, screen area, and videocard requirements.
I have the 2001FP and could not be happier! :)
Doom 3 and Farcry look wonderful in 1600x1200!
I meant that I could get both monitors for around that price each. Sorry for the confusion. I knew that the monitors have different native resolutions, so could you elaborate how that will effect the image quality? I plan on getting an x800 XT Platinum, so video card power is not an issue, but until those become more readily available, I'm using a ATi 9800 AIW to hold me over. I like how the Dell monitor has extra inputs, but I believe I can hook my consoles up through my video card as well. What other type of things can I hook up to the monitor (DVD players, etc)?
It also has s-video in, and a nice USB hub.
I have a 6800 Ultra, and running at 16x12 makes a very big difference.
Especially in games.
There is something else to consider with LCDs and resolution.
Most LCDs (using DVI) go up to a maximum of 60hz. How does this affect you? Well, if you are playing with Vsync on, your game has to sustain 60fps or above so it doesn't drop to half. Unfortunately, most games use double buffering, and if your framerate drops to below the refresh rate, the framerate will be cut in half. So when using an LCD, your game could be running @ 60fps, and then drop to 30fps all of a sudden. The drastic change in framerate will be noticeable. (At least it is to me.)
Now, the reason I bring this up is because depending on how powerful of a video card you have, you may be able to keep that 60fps @ 12x10 and not @ 16x12. Just something to consider.
- D.
Again, this only applies if you are using vsync.
How is the quality of the image when you run your computer at a resolution lower than the native resolution of the monitor? Is it really that noticeable?
On some LCD's it matters. Some scale better then others and the Dell 2001FP is one of the monitors that scales real well.
I have a friend looking at the Sony - and was wondering if anyone could come down on one monitor or the other? Has anyone used both?
Thanks
