Dell 2001fp vs. Samsung 213t
paladin0
For anyone who has had experience with both of these monitors which do you prefer? Which do you prefer for gaming specifically? How bad is ghosting on the 213t?
I just got the Dell 2001fp for $770 and games look great on it but in windows the screen door effect bugs me. Well, some times it bothers me some times I can ignore it. I am debating whether or not it’s worth $500 and potential ghosting on the 213t to not have to deal with the screen door any more.
I just got a Samsung 213T for graduation, and so far I love it. For general usage the monitor rocks. As far as gaming goes, Rise of Nations looks beautiful, and in CS there is a slight motion blur, however it is fine for me, I have been playing a bit and am already used to it. However, gaming is not my top priority, I use my comp for TV/Music/AIM/homework, and this monitor is perfect for my needs. No dead pixels, and the monitor is plain lovely.
I haven't done a lot of gaming on the 213T (just what's on the in-store demo PC it's hooked up to) but so far, I'm finding that my 2001FP handles gaming quite well. It does a surprisingly good job of scaling to non-native resolutions (which is quite helpful, as my PC is badly in need of an upgrade right now and probably wouldn't handle much very well at 1600x1200), and I've also hooked my XBox to the S-Video input with good results. I've got a few pics around here somewhere if you think they'd be helpful (some MAME stuff and a few shots of the XBox running,) but to be honest you can't get a good indication of how well it works from that. I do not notice any significant ghosting, and 60FPS stuff seems to run pretty well, all things considered.
One of the nice features on the S-Video input is that it that has 3 modes to display the picture in: 1:1 (no scaling at all, pretty much useless, although it does also have PiP capability on the VGA and DVI inputs), Aspect (Scales up, but preserves the aspect ratio. This leaves black bars above and below) and stretch, which uses the full scren. I just use stretch most of the time, since I find the difference in image quality negligible. Of course, should you find that you don't have use for the S-Video input, you may ignore this part.
i really love my dell 2001fp, i have never owned a 213T but i have used them before, and i would pick the 2001fp over the 213t. the screen is only 1" smaller, its got 16ms response, i like the looks and features more, and it costs alot less
I've had my 2001FP since they first came out last year and I must admit that I'm still happy with it do this day because I'm the kind of person who gets bored of 'puter hardware pretty darn quick.
Just make sure you use DVI as your interface. There is a significant difference in performance over 15 pin vga
I am an FPS fan and the only time i realy noticed motion blurr was in Far Cry during a fire fight against multiple combatants. It was a bit unnerving, alot of jungle and I found it hard to get my barings for a second or two. That was the only time. (Or my eyes permantely adjusted to it)
"Either way"
CS : No issues
UT2004 : No noticiable issues
Far Cry : See Above
DeusEX 2 : no issues
PS: Use the Samsung driver and make sure you have a high performance video card and your fine. The monitor is un surpased as an all around screen and pretty dam good with the games. I have no regrett haveing come from a Sony CPD-G500 21 Aperature grill CRT
PS: By the way Samsung may be doing a shell game. My black 213T (newest ) Seems to be better in gaming than my Silver one. I wonder if they changed film type? No I think its just the color .
Thanks for the input everyone.
I have a feeling since im so picky about the screen door on the 2001fp ill be just as picky on about the small ammount of ghosting on the 213t. I cant win.
Is any one aware of any new 16ms 20 or 21 inch screen coming out?
phillips is coming out with a 12ms 19" lcd. and viewsonic makes a 20.1" 16ms lcd.
The 20.1" view sonic is contains the same panel as the dell 2001fp so it would still have the annoying screen door grain effect.
As for the 12 ms phillips ill have to look into that it sounds good.
I suspect that any 12 ms screen will have that effect and that it is inherant with that type of panel. There will be no excaping it?
I have 2 2001fp and I had a 213t. I all repsects the 213 was better. The only reason I sold it was a style issue. These panels are a crapshoot to not get dead pixels. Both of mine have screendoor and this sparkly overlay on the screen which is annoying as hell. My 213 had none of that. I have backlight problems on both. My testament is the 213 was better. Up to you though.
Good to hear I will be checking out the 213t at a store soon. One question though you say you sold your 213t for a style issue, you mean you didnt like the caseing/colors. Isn't the black model pretty close to how a 2001fp looks?
It seems you liked the 213t more but still got rid of it.
Since I had 2 black 2001's I figured theyd match up better then 1 213 and 1 2001. Believe me I wish I had enought money to buy a 2nd 213. If I were to get one I'd get either. I like both black and silver. Just not 2 dif panels.
I can definitely vouch for the graininess. It does look like a screen door for sure. It is awesmoe for gaming though.
I have been debating getting a new and/or different 20+ LCD monitor. I have 8 dead pixels now to, and I can't return it because I do not have a Customer/Order # from Dell. I bought it from a lady on ebay.......So I am sh*t out of luck.
Ok that makes perfect sense not many have $2500 to blow on a pair of monitors, except for jacuzz1 :). The different panels would really bother me as well. Especially since the Samsung would be a little larger and make everything look asymmetrical.
I agree this monitor is ideally suited for gaming. My eyes don’t have time to spot the graininess and since it has such a low response time there is no ghosting at all. I really love playing games on it.
Do the 8 dead pixels bother you that much? I closely scanned mine to spot the 10 or 15 I found, but under normal viewing I maybe notice one every couple hours and it doesn’t even bother me.
Hi 213T owners, just a quick question:
Is a DVI cable included and is it a single one or a dual one?
yeah, i can't see the dead pixels, unless I am watching a movie and i can see them through the black borders. But normal web browsing, no I can't see them at all.
So, thats why I am torn if I should even try to return it.
It seems that the "screen door" issue is endemic to many LCDs larger than 18.1 inches.
I've had a Samsung 181T for two years now and it's great (good pixel density, no dead pixels, and running on DVI), but I recently bought a 191T+ for the hell of it and noticed the "screen door" effect right away, while looking at it from the same distance as my 181T. It bugged me so much I returned it and kept my 181T.
Screen door, I haven't seen it in a while. I don't know anyone with a 2001, I'd like to see what all you keep blabbing about. I don't sit 6" from my display though, and my NEC has no issues other than it does have some motion blur in some games, although for BF:V it's fine.
Had my Dell since February and love it. I do notice the screen door effect everyone once in a while but it's more of, what the hell did i just see type thing cuz it goes away. Like when my eye's focus a certain way.
I think the price/performance did it for me. The money I saved I bought a nice video card to upgrade to dvi.
It was very noticeable from a normal 2-3' viewing distance at over 4 feet i didnt really notice it, but i also couldn’t read text too well.
My second 2001FP will be picked up tomorrow by ups. The screen door was just too much.
For the time being I have traded monitors with a friend, my pf790 crt for his dell 1702fp (35ms version). Even though this lcd is old and ugly it does not have any screen door noticeable by my eyes. Also I learned that ghosting does not bother me, I do not notice it in Far Cry or UT2004. I did see it on that monitorsdirect test with the 4 white boxes moving around though. Since ghosting on a 35ms panel doesnt bother me much, I think I may just pick up a Samsung 213T. Since it has superior image quality to the 2001fp and 25ms level ghosting probably won’t bother me in the slightest.
$1200 is still a lot of money though. I'll probably go check one out tomorrow at a B&M store to make sure it looks good to me. Do 213ts ever go on sale? Seems to be 1200 everywhere i look online or local store.
Yes it comes with a single DVI and a single 15Pin VGA
jacuzz1, on your 213ts do you notice any ghosting or motion blur?
Ive been using a 35ms panel for a week and it had some motion blur in games (halo) which is only slightly annoying. Much less annoying than the screen door of the 2001fp.
As soon as dell has a 20% or 25% off monitors sale im probably getting a 213t.
One excemption was in far cry. I initiated a fire fight with multiple contacts in plush jungle to test the screen. A significant amount of ghosting took place. Bare in mind this was under the most extreme conditions and the only time I found it a problem.
Resolution was 1600x 1200 , 32 bit color 2x AA 8 x AF. 9800xt. Bare in mind that the video card was stressing as well and it could have been frame rates dropping below exceptable levels. The moral of the story is that I rarely if ever feel the screen is ghosting , even in UT2004. You wont be dissappointed in this screen. I believe Samsung uses a proprietary film and 25 ms is not the same as on other screens.
PS: DVI all the way , if you dont have DVI out on you video card then dont spend all that cash on the 213T You will get motion blurr on the analoug. Needless to say if you have the coin for this screen you should allready own a video card worthy of it.
I got my black one from Dell for just under 1200. I then got another $90 off because i complained about an open box when it arrived. The screen is mint. Oddly enough the black one (newest) games better than my silver. Perhaps they have improved it.
Good to hear I was planning of getting mine in black. Im sure they are all the same now anyway though. What was the normal price when you bought it from dell, $1330 like it is now?
I paid 1,257.36 landed and then extorted a $90 coupon out of them for the open box and promptly purchased Nero Ultimate eddtion with the coupon :D
