Dell 2001FP or Dell 2005FPW???
jyi786
I can't seem to make up my mind, and I need your help. I've read comparisons here and elsewhere, but they really don't touch on the issues I have between these two panels.
2005FPW cons
1. Backlight
2. Non-native 4:3 resolution??? (correct me if I'm wrong, but if I get this monitor, it means my whole 100+ hi-res wallpaper assortment will not be able to properly fit on this monitor unless the image is stretched!!! :( )
2001FP cons
1. SCREENDOOR. If it's really that bad, I don't want it. I'm not looking at a screendoor when I'm photochopping (>>annoying if true).
2. Non widescreen. Will I really lose that much estate by going non-widescreen?
The prices are almost equivalent, so I need to make up my mind soon.
Please help. :(
2005FPW cons
1. Backlight
2001FP cons
Please help. :(
I dont think you lose any real estate... 1600x1200 > 1680x 1050 in my calculator :p
Seems like it should come down to what you're using it for most. the 2001FP is 1600x1200, so it technically has more screen real estate (more pixels), though it's 4:3. If you plan to watch movies a lot, the 2005FPW might work out better, since widescreen movies will fill more of the screen. And yes, you would have to resize your desktop collection (or let them be stretched) if you wanted them to cover the entire screen.
Not sure what you mean by listing "backlight" as a con on the 2005 FPW. They're both backlit. Are there issues with the 2005FPW backlight?
I think the "screendoor" effect is common to any LCD, it just might be more apparent in some than others. There was a thread here or on anandtech recently that had some pics showing it, and it seemed to me that it was impossible to see unless your eyes were 2 inches from the screen all the time. Kinda like with a CRT, if you get close enough, you can see the grid of the shadow mask thingie (whose actual name escapes me atm).
I just picked up a 2001FP as i don't watch movies on my PC, and the games i play most often don't support widescreen modes. I also wanted to be able to rotate the screen to view long pages (i may never do that, but it sounds like a good idea).
There is a huge thread on here regarding the backlighting problem of the 2005FPW. And the screendoor effect, I really don't know because I'd rather not stare at a screendoor when I photochop.
Well thats quite a hard decision, but I found it hard to understand the screen door effect since i didnt actually notice it until i stared at it trying to figure out what's wrong.
2005FPW isn't for everyone, and beast made a very good statement explaining this. What i do, is this (its a 1280x1024 wallpaper)
I had some widescreen wallpapers on, but sometimes its nice to have a slightly more calm wallpaper. But it is a bit difficult to find widescreen wallpapers.
Gaming is a slightly more immersive experience, and it just feels really cool to have a widescreen when using it. I get alot of that 'feel good' tingling through my body when i first used it. Essentially it's like having 2 monitors, since you can use the 4:3 mode also. But it will never have the height that the 2001FP has.
More of a decision you can only make based on how you use your computer.
Bah, I bought into the forum madness a few months ago and picked up a 2005fpw right after they started getting so much talk time.
I only have one dead pixel and no real backlight problem, however, I feel most of those who whined on this forum we're simply expecting too much, so I didn't luck out with a good one, instead I just understand the flaws in LCD technology and rolled with it.
This said, if I were to do it all over again I'd go with the 2001fp.
Why?
Because although I LOVE widescreen for desktop use, it flat out sucks in gaming. HL2 and CS:S are great in widescreen, but 90% of the games I play dont support widescreen and I end up with either a streched picture or black bars around my picture.
Also, I have an SLI setup and it's become well reported recently just how much of a problem this can be. SLI and widescreen in games creates HUGE problems. Shaking up and down, black bars all over, etc.
You name it.
Right now SLI and widescreen... well, widescreen through DVI does not seem to be possible without video quality issues.
Overall, the picture on the 2005fpw is outstanding, best I've seen, desktop and graphic use is solid, but for anything related to gaming, it becomes more of a con then a pro. The few games that can use 16:10 it really shows it's strength, but overall there just are not enough supported games to really take advantage of this.
It does appear that Longhorn will bring widescreen gaming to life, at that time expect to see almost all LCD's going widescreen and almost all games supporting such a thing, however, thats years down the road.
Either way you go you'll probably be happy, but be aware of the problems, and finally, if you plan to go SLI avoid widescreen for now, it's nothing but trouble.
2005FPW....definatly.
my g/f has a 2001fp, she envies my 2005fpw....
widescreen gaming = the shit
seriously, 2005FPW...
and you can get new wallpaper thats just as good if not better for your 2005fpw
i know i did.
deviantART.com is a nice place for that if i remember correctly
Why?
You name it.
btw almost any game could be played in widescreen native (not stretched), just go to widescreengamingforum.com and see how ;)
I am sure nvidia will fix the sli issue soon as there is nothing inherently incompatible with widescreen and sli. Probably just a driver issue.
People keep complaining about this - what other possible solution is there, since the 'black bars' 1:1 ratio mode is essentially a 4:3 LCD. As I said, you get two monitors with this in a way, a 16:10 monitor, and 4:3.
Also the good site www.widescreengamingforum.com has alot of help if you need it, including fixes for games that don't have the widescreen option built into the game. GRAFiZ is also true with the support, it may become widespread norm to have a widescreen LCD in the future, but that may be a distance away. However there are now the ACD's and the FPW's that are popular which could boost this recognition, who knows.
Also i can't back you up on the SLI part, because sadly i cannot afford an SLI rig! But you are referring to DVI problems with SLI, not DVI in general, are you?
O yea, Adriana Lima is my girlfriend. LOL I WISH :( Man i need to go to Brazil.
True... I've been to www.widescreengamingforum.com many a time... it's in my favorites.
However, even using the "mods" and hacks, there are always problems. Run through a dozen games when you're bored and you'll see. Some take the change well, others really b*tch about it.
One of my current favorite games is Pirates!, and even with modding the ini file, it will run in full screen, but all the text gets shifted off the screen. No fix as of yet.
Other games when running in full screen get a touch jumpy or skip now and then, while it does work, it just aint as easy and or smooth as 4:3.
I hope it is, however, you have to admit, when you plop down thousands to get the best performance, only to be slapped around by poor QC and terrible driver support you get a bit frustraited.
Honestly, when ATI get's their SLI up and going, I might switch, Nvidia has GOT to get on the ball if they want to keep my wallet.
Widescreen even with hacks is still a rough adventure, it hasn't been near as smooth a transistion as I hoped.
As for the problems I've having on top of that, it does seem to be a problem with SLI and DVI, not DVI alone.
I used to run my 2005fpw using DVI from my BFG 6800ultra and never experienced any of these shakes or lines I get now, running through DVI.
That is to say, those problems are totally removed from compatability of games, and is instead a hardware or driver issue.
I agree - games put up a tough fight if they have the widescreen aspect of gaming totally ignored. It seems that only well made and supported games have widescreen support, or can easily be widescreen hacked, such as UT2004 and HL2/CSS. As you said, we have to wait until widescreen becomes widely accepted.
