Dell 2001FP color settings
zan780
Most monitors have settings like "9300K, 6500K, etc". However on my 2001FP the settings are: "Blue preset, normal preset, red preset, and user preset."
Is there software to calibrate color? Does anyone know how to tell what color temp I am running?
Thanks,
Z
Not sure what temperature but after some playing around I have found that I like these settings best. You could try them and see what you think.
User defined color:
Red 40
Green 50
Blue 50
I tried that one, and thought the white looked a bit off (a bit too brown, it seemed.) I'm still tinkering with my settings.
I keep tinkering, but I currently have mine at:
Red: 45
Green: 50
Blue: 67
Those settings alone didn't do it for me. Futzing with Gamma, Contrast, and Brightness settings in my ATI display driver settings in Display Properties really helped me.
